im talkin about motor work i only wanna spend about 3000-3500
4mm stroker crank...$600
Trail Port... $300
Cool Head... $250
Pistons... $150
Reeds... $60
Carbs... $300
Gaskets... $40
Seal Kit... $45
Timing Plate... $35
Lighten Flywheel... $30
Proflo Kit... $90
Front suspension... $1500
Total... @$3400 :thumbsup:
Should be a real nice trail eater, feel free to add if I missed anything fella's
Edited by slobanshee06
you really wouldn't have to spend all the 3500 on the motor.get yourself i nice dune or aggressive trail port,34mm carbs,get your stock head cut or get a noss head with 19cc domes depending on what fuel you want to run,adjustable timing plate.you will only have about 1200 at the most in the motor.and the rest of the money to play with on the suspension and chassis.
Edited by 00tbanshee
