going to be changing my color anyone ever strip there paint off before. I did a search and all there was is how to remove paint of the engine. So I looking for tips, how to's, or what product to use. Thanks guys
Aircraft paint remover. Takes paint of anything, just be careful of the shit, its nasty to get on you or breathe. It will seriousley burn the hell out of you if it gets on your skin.
I wouldnt let it sit on plastic very lit long, if at all. I let the aircraft remover soak for about 30 min then I used fine steel wool to scrub it off. Be sure to wear gloves, as mentioned....this shit is painful on your skin.
i used that tal aircraft paint stripper on the rims and frame of my tl1000r and it burned the hell out of my skin and i got some on the tire when doing the rims and it started making the rubber soft. so my advice would be dont get it near any plastic or rubber.
easy off oven cleaner , believe it or not, is a safe paint remover to use on plastic. its not quite as bad ass ast the aircraft stuff, but it wont turn your plastic to a big pile of goo!
