highroller355 Posted December 22, 2007 Report Posted December 22, 2007 i have the intake with cross over tube built in, i am now running 33 pwk's i am going to be running 39 pwk's do i have to buy new intake or can i change intake boots. if so where should i buy them from. thanks in advance. Quote
jbooker82 Posted December 22, 2007 Report Posted December 22, 2007 i have the intake with cross over tube built in, i am now running 33 pwk's i am going to be running 39 pwk's do i have to buy new intake or can i change intake boots. if so where should i buy them from. thanks in advance. Here is a link to the rubber's Pro Flo Mikuni carb boots LINK I believe the ones on the intake for 33-35mm carbs is the vm34-200-1 they have a 60mm center to center. You might check becuse it is possible that they could be the VM32-205-1 wich they have a 75mm center to center. Then you could get the VM38-200-1 for 38mm carbs and they have a center to center of 74.6mm. josh Quote
shanYE west Posted December 22, 2007 Report Posted December 22, 2007 I had to buy new intakes when I switched from 35's to 39's Quote
RUDEDAWG Posted December 22, 2007 Report Posted December 22, 2007 Pm. me if you decide to sell your intake. Quote
highroller355 Posted December 23, 2007 Author Report Posted December 23, 2007 Here is a link to the rubber'sPro Flo Mikuni carb boots LINK I believe the ones on the intake for 33-35mm carbs is the vm34-200-1 they have a 60mm center to center. You might check becuse it is possible that they could be the VM32-205-1 wich they have a 75mm center to center. Then you could get the VM38-200-1 for 38mm carbs and they have a center to center of 74.6mm. josh wow jbokker to the rescue, that helps out big time just have to measure my boots now. thanks Quote
jbooker82 Posted December 23, 2007 Report Posted December 23, 2007 wow jbokker to the rescue, that helps out big time just have to measure my boots now. thanks You dont have to measure, just look at the boot. On the lip of the intake you should be able to see that part number. It isnt on the base, or around the out side it is right on the lip. Quote
