Would a set of 34mm carbs be too big for my application? I am going to get port work done on top of what is already done.
depends on what kind of riding you do and what kind of port work you are going to have done
i would personally run either 33mm or 35mm pwk. more common carb and more people run them. that way youll have more people who can help you get them dialed in. for your application id say 33mm would be best. should be able to find some fairly cheap but youll also need intakes for them and prolly a new air filter setup.
