desert nut Posted December 13, 2007 Report Posted December 13, 2007 had no spark replaced coil stator no spark replaced cdi sparked fat took out for test ride no spark again :: so that makes 2 cdi's whats next???????? gas and a match WTF please help me 1996 banshee 350 :verymad: Quote
Screaming Yellow Zonker Posted December 13, 2007 Report Posted December 13, 2007 When that happened to me I went on ebay and bought a new wiring harness. I got a harness from a newer bike so I could run the new style box. *knock on wood* no problems in 5 years. Quote
nitroburner13 Posted December 14, 2007 Report Posted December 14, 2007 i had that happen to me last summer and it turned out that somehow the kill/light switch was shorting out and killing them. disconnected it and had no problems since. just a shot in the dark from my own experience. hope it helps Quote
kawiking Posted December 14, 2007 Report Posted December 14, 2007 my buddy had the same problem.... it ended up being a fucked up stator, then the second time it was a wiring harness that had been sliced acouple of times. Quote
BellicoseBanshee Posted December 14, 2007 Report Posted December 14, 2007 Definately check ALL the other electrical components and the wire harness... Quote
jmd0346 Posted December 15, 2007 Report Posted December 15, 2007 Stock flywheel? Had a Ricky Stator flywheel burn up 5 or 6 stators. Quote
desert nut Posted December 28, 2007 Author Report Posted December 28, 2007 got working ended up being f$%&ed up mechanic left my flywheel loose Quote
