Clean them really good, then spray a light coat of WD-40 or similar oil and scrub them with extra fine (000) steel wool...works very well. Do small areas at a time, use a small amount of pressure, and keep the areas lubricated. Use tapping oil and fine (00) steel wool to remove stubborn spots, such as rust, riding pant residue, etc. Work the areas that turned blue with the extra fine steel wool and it will look pretty good, too. :thumbsup:
Steel Wool Grade Chart :beer:
Finish up with some NeverDull.
I cleaned up some pretty pitted up inframe pipes...has them looking good with some real fine steel wool and Liquid Wrench, then never dull. Took quite a few hours...a beer or two ..LOL, but they turned out nice...
Followed up with an Acetone rub down. Gets all rid of all the polish, and finger prints.
I used easy off oven cleaner. worked awsome. i put them in the oven at 200 degrees for 30 min then removed them and sprayed them with easy off, turned the oven off, then put them back in for 15 min., wiped them off and rensed with water and they look great. only draw back was the wife came home from work and said how nice i was for cooking dinner till she opened the oven...... :whistling:
that just made my nite lmfao :biggrin:
they arent only blued but there is like dirt that is like baked on ... ill see what i can do with your guys' methods..
I used GS27 polish, it's for scratched paint and polishing bumpers, i was amazed! worked pretty good with alot of elbo grease
