BANSHEEE Posted November 11, 2007 Report Posted November 11, 2007 Just did a top end rebuild +3 prolites bike started ran fine synced the carbs everything was nice shut the bike off wont start.Replaced stator,coil,pickup sensor,plugs,cdi,and still bike gets one spark and won't start.Checked for grounds loosewire/broken wires every thing looks good and ohmed out good.key is removed and bike still has tors. thanks for any help. Quote
Screaming Yellow Zonker Posted November 12, 2007 Report Posted November 12, 2007 unplug that tors box by the coil and it should start up. Do a search for the complete tors removal. I would recommend taking it all off your bike. Quote
blowit Posted November 12, 2007 Report Posted November 12, 2007 Just did a top end rebuild +3 prolites bike started ran fine synced the carbs everything was nice shut the bike off wont start.Replaced stator,coil,pickup sensor,plugs,cdi,and still bike gets one spark and won't start.Checked for grounds loosewire/broken wires every thing looks good and ohmed out good.key is removed and bike still has tors. thanks for any help. did you by chance do any painting? Gotta watch the grounds. You will find your answer with your meter. If the stator specs show good as well as coil, you can move ahead to pulser coil gap to flywheel, and grounds. black/white stripe should not go to ground unless to kill the bike so find one and test to ground. Also make sure engine grounds to chassis. It will bet it is something simple. Just keep shopping. Also make sure the blade connectors to the coil are tight. You can override the TORS for testing for fire by simply holding the throttle down a bit. The TORS only does its job at idle conditions. Brandon Quote
BANSHEEE Posted November 12, 2007 Author Report Posted November 12, 2007 No Paint i will go back at it after work tomorrow with a meter again and disconect the tors and go from there. With the tors hooked up and WOT no spark but i will still disconect it and go from there.By any chance do u guy think it has something to do with the carbs/throttle cable. :: Quote
BANSHEEE Posted November 13, 2007 Author Report Posted November 13, 2007 Didn't get a chance to look at the SHee today but did order the Toomey Thumb Throttle Kit to get rid of the TORS will update soon. Thanks for the helpful information Quote
BANSHEEE Posted November 15, 2007 Author Report Posted November 15, 2007 Finally got the banshee going found a broken wire in the harness that was used for the key.Heat shrunk the ends and repaired the ground wire by the cdi bike idles smooth and starts right up. thanks again Quote
