orion39 Posted November 5, 2007 Report Posted November 5, 2007 I have works dual rate remote reservoir shocks on my Banshee that I bought less than a year ago for mxing. When I got home today after a day of rding I noticed that one of my springs is rubbing against the shock absorber. Could I have bent the shock or is there a way to fix my problem? Quote
RoostRocket Posted November 5, 2007 Report Posted November 5, 2007 post a pic of the problem that will help us help you...is it the shaft that it is rubbing on??? if so i would say it would have to be bent. Quote
orion39 Posted November 5, 2007 Author Report Posted November 5, 2007 post a pic of the problem that will help us help you...is it the shaft that it is rubbing on??? if so i would say it would have to be bent. I can't figure out how to post the pic b/c it is bigger than 50k, but the spring is rubbing against the shaft. Quote
RoostRocket Posted November 5, 2007 Report Posted November 5, 2007 I can't figure out how to post the pic b/c it is bigger than 50k, but the spring is rubbing against the shaft. get a photobucket account and download your pics there then click the image tag and paste it over here. if the shaft was bent you should be able to tell pretty easily. i bent some stockers and they were very obvious even though it was a small bend. Quote
orion39 Posted November 5, 2007 Author Report Posted November 5, 2007 I hope the pic worked. You can see the dark spot on the left side of the shock. That's where it's rubbing. Thanks for the pic advice. Quote
RoostRocket Posted November 5, 2007 Report Posted November 5, 2007 i would say as long as it is not binding then you should be fine. it doesnt look that bad to me, i have seen that happen before. Quote
orion39 Posted November 6, 2007 Author Report Posted November 6, 2007 i would say as long as it is not binding then you should be fine. it doesnt look that bad to me, i have seen that happen before. The problem is that it is rubbing hard enough that it slows the recoil of the shock. Quote
