Lethaface Posted November 4, 2007 Author Report Posted November 4, 2007 (edited) A-arms and spindles gone.. Will do a packaged deal on the cub set up.. Will include Cub cylinders, Stroker Crank, Cool head, pistons and domes for $1225 shipped plus paypal fee's.. Also will do $1600 + PP fees and include the tranny. 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 12. Complete Electrical system from a 99 banshee. Comes with stator with modded timing plate all wires, Coil and a working CDI and wiring harness. Headlight harness was cut of for billet lights. $150 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120 Edited November 4, 2007 by Lethaface Quote
kawiking Posted November 5, 2007 Report Posted November 5, 2007 why you guys parting out your bikes ?? you can tell you had alot of time in that bike !!! BUMP... good luck with the sale. Quote
Lethaface Posted November 5, 2007 Author Report Posted November 5, 2007 Kawi, He was my only competition.. he parted out to get married so the closest bike was running 9.10's lol.. So i decided to just do a car project.. Few more things i didn't have pictures of earlier. Sprocket and sprocket hub Modquad bar clamp Chrome Shifter, brake lever and kickstarter. Trinity Stage lV intakes for 39mm carbs and extra set of boots for 34-36mm carbs Quote
Lethaface Posted November 5, 2007 Author Report Posted November 5, 2007 1. 421 68mm cheetah cub cylinders with pistons and wrist pin bearings $750 2. Hot Rods 4mm Longrod Crank like new 3 weekends on it. $350 3. Pro Design Cool Head with BB 18cc domes $170 4. RDZ 1-5 override with neutral down. PERFECT SHAPE! $400 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 8. Majic Performance Lockup and polished Lock up cover. $300 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 11. Trinity Stage lV intakes for 38-40mm Carbs Also comes with a extra set of boots that fit a 34-36mm carb. No issues like cracking or anything like that. $140 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 17. Axle Carrier from a 04 with brand new bearings and seals. $45 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 21. Complete set of a-arms, spindles and tie rods. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120 35. Working CDI from a 99. $55 36. Coil, Wiring harness and voltage regultor $55 Quote
kawiking Posted November 5, 2007 Report Posted November 5, 2007 i feel yea you. we have been working 6 days a week since may , so ive rode my bikes twices.... i ve been thinking of buying a older mustang to play with. i just cant sell my bikes !!! plus dont think i'd have time for a car project. well good luck !!! Quote
Lethaface Posted November 6, 2007 Author Report Posted November 6, 2007 Updated list! 3. Pro Design Cool Head shell. No domes $110 6. Flow Tech 12oz Lightened Flywheel Good shape LOOKS NEW! $100 10. 39MM PWK's. Comes with all fuel lines, Mikuni fuel pump, Modded bowls for more fuel, Clamp on K&N filters and a Dual Feed Pingel and dave moore super jets. $475 14. Billet Case saver. A little bit of material was removed to fit a 16 tooth front sprocket. $30 15. CFM +6 swingarm. Good bearings! Comes with a chain and UPP long chain slide. Also comes with a +6 stainless steel brake line. $175 16. Polished axle $70 18. Rear sprocket carrier and brand new JT 40 tooth Chrome Rear Sprocket. $40 19. Complete set of Special Edition Yellow Plastics. Comes with a one of a kind Texas Chainsaw masacre Graphic Kit. Also comes with a custom made Chainsaw grille. This is the only Set of graphics and grille like this in the country. Plastics are in very good shape.. Not scratched up and beat like a trail bike. $300 20. Custom made seat. Was profesionally cut then had $25 a square yard vinyl stretched over it. Comes with pan and good working latch! Paid 110 for the work alone. $120 22. Front and rear hubs. Good bearings and seals in the front! $70 23. Complete break system. Comes with front and rear calipers, master cylinders and MSR front brake Lever. $150 24. MSR Adjust on the fly clutch lever. Comes with a brand new MSR terminator Ceramic clutch cable. $50 26. Complete set of drag wheels and tires. Will come with a set of ITP rear wheels with Hoosiers and a set of 4" douglas front wheels with drag tires. Very nice wheels not bent or dented up. $350 27. Motor mounts and motor mount bolts. This will be upper and lower strut mounts. $30 28. Complete banshee bolt set. Most have been replaced with stainless steel allen head bolts. $50 29. Billet Handle bar clamp from MODQUAD. Very nice looking! no dents or dings. $25 31. Polished stock kicker. No clanging or noises its still tight!.. $50 32. Stock Thumb throttle with polished Cap. Harness still attatched $35 33. Chrome Rear brake Lever and Shifter. VERY NICE! $60 34. KBC gunslinger helmet size XL. very good shape. $120 Quote
