riderofthestorm Posted October 27, 2007 Report Posted October 27, 2007 i am lookin to change my rear tires back to stock size,, i currently have 20-10-9 bandit tires on itp wheels,, i just don't get enough traction with them, my clymer book says in 88 stock size was 22-10-9, i figure this might give me some more ground clearance as well,, but i'v been lookin at the bear claw tires by kenda but i can only get them in 22-12-9, will the size be ok? they look to be a good aggressive tire plus they're 6 ply!! has anyone ever tried these on they're shee?, i used to have shredders on my old quad and they seemed to do really well too! will a heavier tire help with traction? i'm open to any suggestions,, thanks guys Quote
riderofthestorm Posted October 27, 2007 Author Report Posted October 27, 2007 i was also lookin at tires from BKT called WING? has anyone tried them? Quote
xXBlessedWithDeathXx Posted October 27, 2007 Report Posted October 27, 2007 Where do you ride? what do you do? Quote
shee rips Posted October 27, 2007 Report Posted October 27, 2007 bearclaws hook up very well, but they are also very heavy. they make the quad feel sluggish and they take away the snap when you hit powerband. and they will fit your rim just fine. Quote
Klotzban1 Posted October 27, 2007 Report Posted October 27, 2007 :biggrin: I ride alot of fields and dirt! I run Maxxis Razers 20x10x10 (Douglas .160) on my 97 shee and had no problem grabbing earth when needed. My rear hubs are from an 89 banshee which gives me the same width bolt pattern as my front hubs. I run a aftermarket 15 tooth front sprocket with a stock rear sprocket along with the size 10 wheel but my tire height remained the same as stock. I feel that my shee performs well. I chose maxxis razers because of the narly look of the beefy x's and the flat track appearance. I took my shee to St. Joe national park and my razers never had a problem on loose sand like chat. In the trails I had the traction and in the soft flats I could feel my shee pull hard. :cool: Don't just take my advice though.....everyone runs different earth grabbers on their shees. Razers work for me and thats my choice for the life of my shee. Quote
socal909 Posted October 27, 2007 Report Posted October 27, 2007 i put pair of itp holeshots on my girls blaster and it made a world difference! Quote
riderofthestorm Posted October 27, 2007 Author Report Posted October 27, 2007 I have all kinds of terrain where i live,, shale, gravel, mud, coal, rocky,, i do alot of hillclimbing, and trail riding, and hit the jumps when they are there,, alot of the hills around here are shale tho, so i'd like to have 6 ply,, i just know with the bandits on trails with alot of leaves i can barely make a hill,, it just spins all over the place Quote
black sunshine Posted October 27, 2007 Report Posted October 27, 2007 Short of ice picks, nothing is going to hook up on layers of leaves. I have Razr II's, they hook up great while still being low profile :thumbsup: Quote
xXBlessedWithDeathXx Posted October 27, 2007 Report Posted October 27, 2007 Look into this tire. my gearing is 13 / 41 tire size 22" click Quote
RIPRuck Posted October 27, 2007 Report Posted October 27, 2007 (edited) Razr 2's are nasty! Beefy knobs and 6 ply.. I just bought a set of fronts and rears and switching over from bandits myself, they just werent doing it for the trails. Will be mounting them and testing out this week but they sure look like they can cause some damage. Edited October 27, 2007 by RIPRuck Quote
locogato11283 Posted October 28, 2007 Report Posted October 28, 2007 kenda knarlys or stock yfz450 tires. they are both cheap, last a long time in all conditions and hook hard. plus they are a lot lighter than razr or any other tire.. Quote
RagunCajun Posted October 28, 2007 Report Posted October 28, 2007 i have cut knarlys. work great for strait line/trails. they are a little rough though. Quote
GleasmJA Posted October 28, 2007 Report Posted October 28, 2007 i have run ohtsu tires many times and love them. They wear a lot though if riding the roads. take a look, they are almost stock 400ex tires. ohtsu Quote
black sunshine Posted October 28, 2007 Report Posted October 28, 2007 Those ^^^^^^^ are the bomb! What they are is stock 250r tires, at least in 1988. They hook up great in hard dirt, gravel, even loamy stuff. Jeff@FAST sells these for around the same price. Really awesome tire and light as a mofo!!!! Quote
350BANSHEE350 Posted October 28, 2007 Report Posted October 28, 2007 (edited) i run 22 gators on the back, in the mud if its think i can pull te front end up they are heavy tough thats what you get with 6 ply but i find that the front of the shees are heavier then the back so putting the big tires on the back make it eaqual out a bit. i would also make sure you have some pretty tall front tires like true 21 or 22 tires not stock front tires because they make the shee look like a tractor. if you ride gravel and stuff i was looking at some other tires i well give you a link for that i think might work well http://www.rockymountainatv.com/productDet...dFamilyId=17493 http://www.rockymountainatv.com/productDet...dFamilyId=11867 Edited October 28, 2007 by 350BANSHEE350 Quote
