Does anyone in here run on E-85? I am thinking about trying an E-85 setup. It's is cheaper than premium and is rated at 105 engine octane so why not right? Any feedback, tips, tunes, or etc. would be helpful. :biggrin:
Do a search...it's been a hot topic. Don't forget, Ethanol is corrosive, not as much as methanol, but more so that you can't just let it sit in your tank and carbs...
There's a good topic on this already, don't just buy it and dump it in, you will require jetting changes, etc...
Even though it's cheaper, you will go through more of it than gas...so, weigh that too.
:thumbsup:
You will have to run a premix oil that will blend with Alachol. Most oils dont.
Klotz Benol, Klotz Supertechniplate, Klotz R50, Maxim Caster 927 will.
:thumbsup:
R50 does NOT blend with alcohol...and I don't suggest using it in purge gas either...
I run Benoil with my meth, and I was using R50 in my purge. It gummed my carbs up something fierce because it's not methanol compatible....
Click on the "tech sheet"
http://www.klotzlube.com/storeProdDetails.asp?pi=19
dave, did ya happen to look at benols tech sheet?? says it will not stay in suspension under 35 degrees! no good on the ice man!!
Shake the can before you run...:) I'm sure if you let it sit it'll separate in cold. I'm positive once you're bouncing around the ice and give it a quick shake...it'll stay mixed...
Sorry about that. I just figured Supetechniplate was 20% Benol Caster oil, and 80% R50. Since you can mix supertechniplate with alachol I figured you would be good to go on R50. My bad.
You gotta re-jet.
Like Dave said, it's gonna use alot more fuel. I promise you wont save any $$.
Especially if you are using more oil too.
Sup Dave ?
Sup Red ?
E-85 is good fuel and makes lots of power. Never messed with it in a banshee, but majicmike has a raptor on it and it rips hard. We had to richen the hell out of the MAP to get it to run (i think we added 40% more fuel to the map) so you will have to re-jet. Here is the E-85 topic Dave was talking about finding in a search.
CLICK HERE FOR E-85 LINK
