my jetting has been the same and the temp has dropped 10-15 degrees.what could cause this?
do you have a temp gauge...there are alot of reasons to spit coolant, not just running hot... psi test the cap for starters
as the temps drop, your jetting will lean out some. 10 to 15 degrees doesn't really sound like much tho. however, if you were a tad on the lean side before and the lower temps are just pushing you to that point, then it's possible. try richening the main jet a smidge and / or raising the needle a clip and see if it cures it.
yea im runnig the
30mm okos. 155 main 52 pilot 2 turns out with 4th clip on needle. which way will it richen up on the needle up or down?
you might try going to the 5th clip, raising it one more position. do you spend most of your time at WOT or at 1/2 throttle? How and where do you ride? Going up on the mains one size would probably work as well and I'd consider trying it.
no for the mains. because im more of a 1/2 throttle guy but am wot alot to. but i pulls and runs great. i was considering just changing the needle because of the weather and o be safe
sounds good then. you're on the right track.
