buddy has a banshee that its sputtering mid to high range. its did it since he has had it. we have put reeds,bored it and put new piston and rings in it and still does it.we did all of that cause it needed it anyway i am thinking it might be cdi box,stator or coil. what do you all think it is or if one of the three what should he try first?
When you open up the petcock valve does the gas drain fast or really slow? Mine was bogging out this weekend and it turned out to be a clogged fuel filter. My buddies 450r was doin the same this weekend and it turned out to be it was getting vapor lock from the one way valve on the gas lid, Just some ideas.
jetting,fuel line,carbs and pickup gap good. no he hasn't moved the cdi box
[/quote
check the connection at the coil the ground and the power. it happens to me all the time
what color wire you check
