atvcraze Posted August 27, 2007 Report Posted August 27, 2007 well when i was tapping out the carb to put the idle screw in for the tors kit it snapped and i had to get the tap out. so after i got it out the idle screw, it would screw in. i then re-threaded it and put a piece of heat shrink on and screwed it in and it worked fine no leaks. just wanted to share a fix. Quote
SoCalinIt Posted August 28, 2007 Report Posted August 28, 2007 Way to make a bad thing into an easy fix! Thanks for sharing man! Quote
