Does anyone have a good way to resurface the bottom mating surface? I'm thinking of making a face plate to put in a lathe chuck and doing it that way. If I did it well enough I could probably bore with it also.
Also does anyone ever match the height of their cylinders? Mine were a little off so today is lapped them both to exactly the same height (meaning head sealing surface and case sealing surface are equidistant from each other). I think this may help the head seal a little better.
chuck lighty on the head end bore in a 3 jaw chuck & indicate the face of the gasket surface. I make sure the deck height is the same on both jugs. I have also had good results with lapping the head gasket side.
good to hear. thanks duner. Tyler, you need to learn some machines dude. You could make some money doing this shit.
