Bansheeman1121 Posted July 25, 2007 Report Posted July 25, 2007 Ok my motor seems to have locked up, heres the wierd thing plugs look fine brown like they always are, didnt run wierd when it happnd just shut off like it was outa gas so i checked the tank and it was pretyty much empty so i towed it home and didnt ride it for a day or 2 and just filled it with gas today went to kick it over and it wont kick any ideas? Quote
400rednEX Posted July 25, 2007 Report Posted July 25, 2007 since a gasket kit is only $20 you might as well take it apart and find out. check the crank too. Quote
blowit Posted July 25, 2007 Report Posted July 25, 2007 Ok my motor seems to have locked up, heres the wierd thing plugs look fine brown like they always are, didnt run wierd when it happnd just shut off like it was outa gas so i checked the tank and it was pretyty much empty so i towed it home and didnt ride it for a day or 2 and just filled it with gas today went to kick it over and it wont kick any ideas? Yep, take it apart. broke skirt or lodged reed. Brandon Quote
joneser4u Posted July 25, 2007 Report Posted July 25, 2007 running it outa gas leaned the shit out of it,could have overheated an seized the rings to the bore.remove the plugs and shoot some wd40 in the cylinders let soak for a few hours and leave the plugs out,put it in gear and rock the bike back and forth to see if it unsticks.If that doesnt work tear it down,even if it has siezed the rings to the bore and it breaks loose,you really need to replace the rings anyway. Quote
