Devans Posted June 23, 2007 Report Posted June 23, 2007 Hey guys after looking i noticed i ordered 14/42 sprockets instead of the stock 14/41 gearing... My question is if i keep the gearing i ordered what will it make my banshee do, faster acceleration or faster top speed? I used to remember all this stuff but i have no clue anymore. Also i am about to order a new chain too, will i be able to use the stock 104 length chain or will i need a longer one? Quote
bansheefreak Posted June 23, 2007 Report Posted June 23, 2007 your gearing for less speed more take off.. but only one tooth .. i would try your stocker first it might have enough slack for one tooth .. then if not order a chain.. but your 14/42 is basically like going 13 and 1/2 in front.. 3 teeth in back equal 1 tooth in front est. basically... bigger in back low(slower but get then sooner) gearing bigger in front high{faster but take longer ) gearing and vice versa.. Quote
Devans Posted June 23, 2007 Author Report Posted June 23, 2007 your gearing for less speed more take off.. but only one tooth .. i would try your stocker first it might have enough slack for one tooth .. then if not order a chain.. but your 14/42 is basically like going 13 and 1/2 in front.. 3 teeth in back equal 1 tooth in front est. basically... bigger in back low(slower but get then sooner) gearing bigger in front high{faster but take longer ) gearing and vice versa.. Cool thanks for straightning that out for me. I just noticed my mistake when i reviewed my order and have yet to try the stock chain. Im sure it ill fit, but i just sent an email to rockymountain because i am missing a piece for my gforce axle and also told them to send me a 104 length chain along with the missing parts... Quote
KaosBanshee44 Posted June 23, 2007 Report Posted June 23, 2007 That's what i run 14/42 and used the same stock chain length. Quote
NYUK Posted June 23, 2007 Report Posted June 23, 2007 it should fit. won`t make hardly a difference. Quote
David Keith Posted June 23, 2007 Report Posted June 23, 2007 Sure it will fit. If you change the total overall length by one tooth, then your axle position will only change by half of a link pitch. Quote
Devans Posted June 23, 2007 Author Report Posted June 23, 2007 Cool cool, i figured it would fit just wanted to know right quick before my new chain is sent... Thanks. Quote
