SAVAGE420 Posted June 13, 2007 Author Report Posted June 13, 2007 I would say it looks a tad on the lean side. When I do my plug checks/chops I usually cut them because you get the most accurate reading like that. Id rather cut the threads and make sure im not running lean better to be safe than sorry. What you need to do is warm the bike up. Pull the plugs and put brand new ones in. Go throught 1-6 and hold it WOT for a few seconds in 5th and 6th. Then pull the clutch,Kill the bike, and coast to a stop. Get back to the shop and cut the threads off. Then after that post the pics up. This will give you a more accurate idea of where you jetting is at. Ok...yeah it pulls hard up top and dosent cut out or seem lean so i geuss im good for now i think will get some 160-162's just to be safe and see whats up. Quote
dajogejr Posted June 13, 2007 Report Posted June 13, 2007 Do this, plugs can take some time to color, and keep in mind...a plug chop ONLY tells you the mains...if done in this manner... http://www.dfn.com/benkaren/plugchop.html Quote
SAVAGE420 Posted June 13, 2007 Author Report Posted June 13, 2007 (edited) Ok i have seen that. and i do every step except for the actual "chop" of the threads and coast fully to a stop (whats the point of the coast to a stop step) i usally coast for a sec or two then skid into where my truck is parked. :biggrin: ....so i guess i will do that when i get my tie rod and end that i bent yesterday. Thanx guys. :cool: Edited June 13, 2007 by savage420 Quote
dajogejr Posted June 13, 2007 Report Posted June 13, 2007 About 3 hours of hard riding. Doesn't sound like every step there...3 hours on plugs will tell you absolutely squat.... You don't need to cut the threads off if you have a light and can look down into the plug...look how thick the ring is..and it's color. Quote
SAVAGE420 Posted June 14, 2007 Author Report Posted June 14, 2007 Doesn't sound like every step there...3 hours on plugs will tell you absolutely squat.... You don't need to cut the threads off if you have a light and can look down into the plug...look how thick the ring is..and it's color. No no no...i rode for 3 hours and THEN checked the plugs with steps above. :happy: Quote
bonbon Posted June 14, 2007 Report Posted June 14, 2007 (edited) No no no...i rode for 3 hours and THEN checked the plugs with steps above. :happy: With a new set of plugs????? Has to be new or completely cleaned up plugs (preferrably new) to see the ring on them....... Here is a pic of what my chop looked like with NEW plugs, notice the ring. Slight bit lean..... Edited June 14, 2007 by bonbon Quote
350BANSHEE350 Posted June 14, 2007 Report Posted June 14, 2007 a 3-4 hours of riding my plugs were darker and wetter than that. can someone please tell me if i need to rejet? i have stock 200s 3rd clip and 3 and 3/4 turns out with the pilot air screw should i leave it like this or jet it properly? like 195 mains 3rd clip and 2 1/2 turns out sound better? my bike is stock with he airbox snorkel off it runs OK but my plugs are usually wet and pretty dark after 3 hours what do plugs look like after 3 hours or supposed to look like thanks Quote
SAVAGE420 Posted June 14, 2007 Author Report Posted June 14, 2007 With a new set of plugs????? Has to be new or completely cleaned up plugs (preferrably new) to see the ring on them....... Here is a pic of what my chop looked like with NEW plugs, notice the ring. Slight bit lean..... Ok so your saying there should be a 2 mm tan ring on the base of the porcilin and clean white all the way up on top? I like mine a bit on the rich side! Quote
bonbon Posted June 14, 2007 Report Posted June 14, 2007 (edited) Ok so your saying there should be a 2 mm tan ring on the base of the porcilin and clean white all the way up on top? I like mine a bit on the rich side! Yes, if you do the chop correctly the only mark on them should be the tan ring at the base and it should be white the rest of the way. A ring just a bit darker than that pic that I put up is what you are looking for. Then you know your mains are dialed in for that temp/humidity/elevation. That link that dajogejr put up is where I learned to do plug chops from. Edited June 14, 2007 by bonbon Quote
KaosBanshee44 Posted June 14, 2007 Report Posted June 14, 2007 Buddy of mine said this the other day while i was rejetting, Lean is MEAN, Rich is a BITCH Definitly agree with him there. Quote
