ok well hear we go again i just had my crank rebuilt my clutch rebuilt and my cylinders checked just got it back together and the noise is still there i can feal it in the kick starter @ high rpms help would b greatly appreciated
It could be your idler gear bushing is worn out, and needs replaced. The stocker is brass, and wears rather quickly. Jeff @ Fast has a steel replacement bushing that works great. Pull the clutch cover, and check the idler gear for side to side play. There shouldn't be any, or very little.
