Hello...
Ok I have a 99 banshee that needs quite a bit of work and I'm not sure what to do and which parts to get. This is what I have done:
FMF fatty pipes and pc2 silencers
pro design air box mod
reed spacers
boyeson reeds on stock reed cages
stock carbs running 320 main jets needle clip raised 2 slots
full drag port on stock cylinders bored out .20 thou with wiseco pistons
stock crank stock rod length
head is stock but planed .30 thou
I rebuilt this bike 2 years ago and I was happy with the engine it worked good and was reliable. I spent a lot of time tuning and tweaking my bike and it has perfect jetting. I always kept the top end fresh but the crank failed on me after a LOT of miles. It always started good and idled good and just plain worked good.
I have a bent connecting rod and it cracked and damaged the lower skirt on my right cylinder. The connecting rod blew the needle bearings out on the crank end and went up into my top end and banged my domes a bit but the head is OK.
the bike needs new cylinders, pistons, and a crank but I'm not sure what kit to buy. I want to fix my motor properly, and I want it to be something I can drive lots. I have been looking around on websites all day but I have read that stroker cranks and big bore kits require a lot of machining and I just want to be able to buy new cylinders, pistons, and a crank and use my stock head with stock carbs. I am getting a TORS endcap kit for my carbs, unless anyone recomends keihns
All my friends are out on their new 450's and I need to get my banshee fixed and put them to shame. help!
I
i'd call jeff at f.a.s.t. or some other builders. i'd try and get all the stuff you need from 1 place since your not in the u.s.a. and you'll get alot better help doing it that away. i'd do it right the first time.
Do you have a website link or a phone number to reach jeff at? Is this place in canada?
call jeff and order his 65 mm cheetah cub and it wont matter if u throw a rod again cuz for 2500 bucks u can have a bullet proof motor that will rape all those 4-pokes.
