highroller355 Posted April 24, 2007 Report Posted April 24, 2007 ok it now idles high with out choke and bogs and stalls the second i give it gas, now on choke idles normal and revs good but under a load stalls Quote
highroller355 Posted April 24, 2007 Author Report Posted April 24, 2007 my mods 396-398 cc 4 mil long rod aggressive port head milled 25 thousandths 175 psi each cylinder 33pwks 48 pilot 165 main needle 3rd clip 110 oct mixed 32;1 shearer inframes k and n pods timing +5 Quote
locogato11283 Posted April 24, 2007 Report Posted April 24, 2007 check your other thread. you need to start looking at other possible problems. that jetting should be fine to get it started and running. the main might be a little rich, but it still shouldnt be doing what its doing. are you getting good spark?? Quote
rhuebner Posted April 24, 2007 Report Posted April 24, 2007 check your other thread. you need to start looking at other possible problems. that jetting should be fine to get it started and running. the main might be a little rich, but it still shouldnt be doing what its doing. are you getting good spark?? I had that same problem and it ended up being the electrical connection that hooks to the parking break, I just completly disconnected it and it ran great. that might be it Quote
