kawiking Posted April 23, 2007 Report Posted April 23, 2007 (edited) i have 150 lbs of compression on my bike,do i need to run race gas or run 50/50 or pump??? i run vp c-12 in my kfx 400 (high comp piston)right now and ive been running 50/50 in my shee.... still on first tank on new rebuild. thanks !! Edited April 23, 2007 by kawiking Quote
locogato11283 Posted April 23, 2007 Report Posted April 23, 2007 if you have 150 pounds id just run pump gas straight. you dont need high octane fuel. Quote
kawiking Posted April 23, 2007 Author Report Posted April 23, 2007 how close to the edge am i ?? if im close id rather run 50/50 to be safe. when should you bump up to 50/50 ??? Quote
06BaNsHeE Posted April 23, 2007 Report Posted April 23, 2007 how close to the edge am i ?? if im close id rather run 50/50 to be safe. when should you bump up to 50/50 ??? 155-160 Quote
!TWISTER! Posted April 23, 2007 Report Posted April 23, 2007 i say pump is fine. I agree. You can't compare 4 Stroke and 2 Stroke, buddy. Quote
FireHead Posted April 23, 2007 Report Posted April 23, 2007 i have 150 lbs of compression on my bike,do i need to run race gas or run 50/50 or pump??? i run vp c-12 in my kfx 400 (high comp piston)right now and ive been running 50/50 in my shee.... still on first tank on new rebuild. thanks !! If you search this forum a bit you will find more info than you ever needed about running race gas. :thumbsup: Quote
kawiking Posted April 23, 2007 Author Report Posted April 23, 2007 would timing or porting change anything. im running 4 1/2 on timing and i have a drag port done.shaved head .030......... i just want to make sure im ok with pump if im on the border id rather be safe and run 50/50.. i have 151 in 1 cyln and 153 in the other... Quote
WALLACE84 Posted April 23, 2007 Report Posted April 23, 2007 I run race gas in anything at 150lbs of compression or above.Thats just me. BUT, If you have porting, then I definalty run race gas Quote
Handyman Posted April 23, 2007 Report Posted April 23, 2007 I have 170 psi on my cheetah p.v. and run straight 110 race gas. i was told that if I had 150-160 to run 50/50 mix of race and pump gas. Quote
locogato11283 Posted April 23, 2007 Report Posted April 23, 2007 yes timing will have an affect on it. better run the 50/50 Quote
kawiking Posted April 23, 2007 Author Report Posted April 23, 2007 thanks for all the info.ive heard the 150-160 50/50..... just wanted to make sure. ive also heard if you run race gas when you dont need it it can hurt you rather than help you. thanks again !!! Quote
FireHead Posted April 23, 2007 Report Posted April 23, 2007 ive also heard if you run race gas when you dont need it it can hurt you rather than help you. thanks again !!! That is 100% correct. If there was anything that was to be learned here it's that. :thumbsup: Quote
