ok ima type this really fast.
i have k%n bolt on pods, 38mm keighns, going to get cases ported by fast along with cylinders (play / dune), vf3's 21cc cool head, +4 timing, AND T-5'S
ok theres a dude on a website in my area whos wanting to trade his shearers for t-5's? i know this wont be around long so i need immediate feedback! shold i do it?
well im not sure what type of setup you have or what type of riding you have... but either way it you end up needing to go back to T-5's you should have no problems finding someone to trade with...
Shearers are a full top end pipe... so if your doing trail riding of any sort or your not on the pipe 90% of the time you ride your Shearers really arnt going to help you much...
Most people move up from T5's to Shearers...you'll have NO problem getting some T5s back if you're not happy with them.
Personally....if you're gonna get 'em, have Jeff drag port your cylinders to take full advantage of them.
I think a dune/play port is suited better to a T5 or Trinity style pipe...MAYBE even an Inframe CPI.
I had both, and currently run the Shearers! If you'er looking for some great drag pipes, the Shearers are the way to go... If you are a trail rider, and like the low and mid range, the T5's are perfect. You'll never know unless you try them out!
Good luck!
