What is the little plastic thing called that a case saver goes over in the cases back by the sproket. I need the short screws to use with no case saver but cant find what that is called.
shift drum plate??
Good stuff fellas. I was coming up blank last night trying to think of it, thanks!
If I'm not mistaking yamaha calls it a nuetral switch cover in there parts finder online.
It's only a neutral switch cover if you have a newer bike. If you have an older Clymer's it's called a shift drum cover as there was no such thing as a neutral safety switch.
http://www.quicksandmotorsports.com/accessories.htm
About half way down the page at the above link you will see where Quicksand calls it a shift drum cover as well. :drag:
http://webforce.nwrain.net/founder/cascade...ORE_DEPT_ID=301
At the above link you will see where Cascade calls it a neutral safety switch cover. Either way, they are the same thing.
Now the real question is: Who wants to buy me one of those covers from Cascade or Quicksand? :ohmy:
wait i thought that comes off to put a case saver on??? i didnt think the case save will fit with it on... but either way case savers do work and are a good way to spend $20. my chain broke and if not for the case saver i would have been fu@@ed.. the case saver was trashed but my case is still in one piece
I put my case savers on over the top of the shift drum cover. I think if you removed the cover and installed a case saver, you may find yourself with a leaky transmission. :confused:
moral of 2 stories keep old short screws incase you sell it :biggrin: or trash it you can still ride
I always keep the screws or anything for that matter, the stupid case deal was on there when i got it. Thats why I didnt have them. :beer:
