The stock crank has tabs on the barrings and the new stroker crank doesn't do I have to do anything to the new crank or does it not need them and just drop it in? also do you guys use any yamabond or anything on the out side rim of seals that touches the case? need input never done this before. oh yeah why does the new crank have seals in the middle of it do they get lubed anything? I have a clymer but doesn't cover these cranks.
Thanks
you dont have to change anything... just drop the new crank in.. make suure you have one half of each keeper or c cliip on top and bottom... also pour some pre mix oil into the webs before you put it in and spin the rods a few times... use yamabond.. but its nopt only on the outside edges its all of the mating surface... anywhere metal touch put some on it... and you do top and bottom not just one... but do go over board with it...
umm cant remember ff the top of my head... i know theres one one the drive sproket side... cant remember if the other has one or not... check your clymers it should say... im at work right now so i cant grab mine...
you olny need one per... you put part of the c on top part of the c on bottom you dont have 2 on one ride...
im i clear in what im saying? i know what im thinking to my self but not sure if its typing out as clear as im seeing the word to my self
I have one on the trany on the drive sprocket one small one on the clutch side on same trany shaft and one big one on the clutch side of the crank. So a total of three but that is only one bearing keeper for the crank. Is that correct not sure what your saying.
yea thats right... i was trying o say that you dont put 2 on one side to make it go all the way around... you use one per and you make the c clip fit in the grooves so half is on the bottom case and ghlaf is on the top case...
ok I get it now half of the clip on each case half.
