highroller355 Posted February 23, 2007 Report Posted February 23, 2007 it sounds like its coming fromthe clutch arm that the clutch cable hooks up to.If you pull the clutch in it goes away let the clutch out a few seconds later it comes back,also at idle, if i bring it off idle maybe 500rpm it will go away, let it idle few seconds it comes back. now my push rod had some blue marks from heat , from the side that goes in the motor by the clutch arm ,could it be that or i think there is a bearing in clutch arm could that be bad and does it spin alot if so how hard is it to change that bearing and seal. Quote
Bansh-eman Posted February 23, 2007 Report Posted February 23, 2007 what does it sound like? ticking squeeking grinding clatter? Quote
highroller355 Posted February 23, 2007 Author Report Posted February 23, 2007 what does it sound like? ticking squeeking grinding clatter? it use to sound like a bad throw out bearing on a stick car .and it just got much louder.does that help at all? Quote
jmd0346 Posted February 23, 2007 Report Posted February 23, 2007 Sounds like a bad needle bearing. Quote
highroller355 Posted February 23, 2007 Author Report Posted February 23, 2007 Sounds like a bad needle bearing. where is that located by the little clutch arm i was talking about if so how hard to change that and can i order the part from local dealer ship or would i get it faster from somewhere else Quote
MDS2106 Posted February 24, 2007 Report Posted February 24, 2007 (edited) Highroller, the push rod has a blueish tint on the ends when it is new.The noise might just be clutch plate chatter.Is the clutch basket grooved? Edited February 24, 2007 by MDS2106 Quote
MDS2106 Posted February 24, 2007 Report Posted February 24, 2007 http://www.bansheehq.com/forums/index.php?...=clutch+chatter Quote
highroller355 Posted February 24, 2007 Author Report Posted February 24, 2007 Highroller, the push rod has a blueish tint on the ends when it is new.The noise might just be clutch plate chatter.Is the clutch basket grooved? basket is brand new .i think it might be the bearing inthe clutch arm that the cable hooks up to ,i will check tonight hopefully .its not a little noise anymore .it got much louder ,so i think somethiing is definetly wrong. and its on the stater side rite by that arm ,not the clutch side .thanks for all the input any other suggestions feel free need all the help i can get.thanks again Quote
