KlotzBanshee Posted January 30, 2007 Report Posted January 30, 2007 Hey, what do you guys recommend to do with your clutch plates while working on the lower end? IDK if they can dry out (fibers) ,or if leaving them soak will make them swell? I'm thinking of just putting them in a zip lock with some Bel-ray in there? They're practically brand new, and I'd hate to ruin them during storage while I work. It will be at least a month before they're ready to go back in. Any thoughts, what do you do? AW Quote
Duner440 Posted January 30, 2007 Report Posted January 30, 2007 I put the clutches in the clutch basket and set them inside the clutch cover when I have my motor apart and I have had no problems. Try to keep them covered up so they dont get any dirt on them. Quote
cam2 Posted January 31, 2007 Report Posted January 31, 2007 I put the clutches in the clutch basket and set them inside the clutch cover when I have my motor apart and I have had no problems. Try to keep them covered up so they dont get any dirt on them. i do the same, i've never had them dry out. letting them soak in oil won't hurt them either because they soak in oil while they're installed in the cases. either way is fine, just keep them from getting dirty as Duner440 said. Quote
mybadbanshee Posted January 31, 2007 Report Posted January 31, 2007 i soak mine when they are out.cut the top off a windshield washer container fill it with case oil and toss em in.also cover it with plastic wrap. Quote
