my tires are like new 2 rides in dirt thats it ,ran something over to day put a 1 inch slice in it not on the side wall should i buy a new set or patch or run tube 22-11-9 itp hole shot i was actually thinking of goin to 20-11-9 or something if i buy new ,can i sell old if so what would they be worth other than that it was a good day put the paddles on finally started hooking
Edited by highroller355
If you can afford new ones go that route... if you want to, patch it, then tube the tire if you just want to use it for a while. I dont think I would use that as a permanent solution, but you could ride on it like that for a while. :thumbsup:
um i would buy new. a machanice told me one time that when you tube a tire on a high hp bike they dont last long. i think he said they spin the tube or something cant really remeber can anyone chime in on this?
I would imagine thats true you could spin the tire on the rim and mess up your tube. I would get new, the tube idea was just a temporary solution until you could get new. :thumbsup:
thanks guy getting new one just deciding whch ones
i worked in a tire shop for many years.....high hp atvs will sipin the rim inside the tire causing the valve stem of the tube to shear off......ive seen it a million times
do yourself a favor and do like you said and get a new tire
Dan
I would get a new tire for the rear..............
If it was on the front I would be tempted to go the tube route, only because the tire wont have the tendency to spin like it would on the back.............
But that is what I would do if it were mine.................
