I have a VP dealer in town and he is trying to get me to run C12 it is a 108 (motor Octain?) leaded fuel. What do you guys think? I am running a stock '06 SE shee. I hope to see some of you at the '07 national BHQ ride out at Little Sahara 03/29/07- 04/01/07 if you don't know about it look at the ride forum it is gonna be sweet :thumbsup:
If you are running a stock shee, as in stock compression, stock timing, you are 100% wasting your money on race/high octane fuel,and may actually be hurting performance.
Straight old out of the pump premium is more than fine for a bone stock motor...even one with a slight bump in compression and timing advance.
More octane burns slower, so the motor does not pre-ignite...a stock or near stock motor is not even close to that unless the jetting is way lean...and even so higher octane won't solve that.
Hope this helps.
Wow I had no clue. I just knew my builder told me to run av gas 100LL and had no clue why.
Cause you got timing and a shit load shaved off your motor...:)
This user said stock...and that is him just wasting money on that bike, I feel!!!
Thanks I figured that would be the case I bought 5 gallons I will just mix it with pump gas 1/2 and 1/2 or less he gave me a great deal on a jug though $15 pretty sweet thanks again --Jet Mech
