I saw a set of LSR Mx chromed a-arms used on ebay, they look in really good shape but i am still not sure if it's safe to buy that even if it's half the retail price. And not sure if it safe to talk about it here, probably the bid will go higher now :shoothead: . What do you think?
You should be alrite as long as they arent bent in any way. Tie rod ball joints ect. LSR are strong Arms. You might have to replace all of the bushings(I think there are 16 bushings) unless stated otherwise. That will run you anywhere from 85-100 and depending on how much you ride you will have to replace them once or twice a year. Thats the only problem with Lonestar. They nickle and dime you on the bushings but they are the best +2+1 A-Arms for the Banshee IMO.
Ok thanks for these infos about the bushings. The bid went real high lately so i will not buy them but keep an eye open for them.
I did it, asked seller many question, everythings seems good, just the price slow me down. I might drop that much money on a brand new set maybe.
What kind of suspention do you plan on getting with your new A-Arms?
For now im looking for a +2 +1 a-arms set somewhere around 500$ and probably Works shocks. I just start shopping but i am long time disapointed with that front end stock set up. Banshee is only 6 months old and the bushing in the shocks are already busted!!
