highroller355 Posted January 8, 2007 Report Posted January 8, 2007 i just put a plus 6 swing arm on with new sprocket and chain with in 10 15 min of riding nothing crazy the chain was jumping then spit off didnt have the guid on by the lower part of the swing arm could that of been the problem is there anything i should get like a special tensioner or guides by the way guys got the stroker back yesterday runs great so far Quote
majicmike Posted January 8, 2007 Report Posted January 8, 2007 i just put a plus 6 swing arm on with new sprocket and chain with in 10 15 min of riding nothing crazy the chain was jumping then spit off didnt have the guid on by the lower part of the swing arm could that of been the problem is there anything i should get like a special tensioner or guides by the way guys got the stroker back yesterday runs great so far IMO that guide is very impartant I would put one on Thats my .02 Quote
highroller355 Posted January 8, 2007 Author Report Posted January 8, 2007 IMO that guide is very impartant I would put one on Thats my .02 ya figured that i have the stock one im gonna put back on is there a better one that i should get and what about the guides up frontthose are stock also are they good or is there an after market that works a little better Quote
majicmike Posted January 8, 2007 Report Posted January 8, 2007 ya figured that i have the stock one im gonna put back on is there a better one that i should get and what about the guides up frontthose are stock also are they good or is there an after market that works a little better I use the stock or upp chain guides and a upp chain slide up front Quote
Bansh-eman Posted January 8, 2007 Report Posted January 8, 2007 check your splines on your axle and hub make sure its not miving... polish had the same problem and that was the cause of it.. Quote
odaen Posted January 8, 2007 Report Posted January 8, 2007 I'd check the alignment of your front and rear sprockets, play in the rear sprocket (either from the previously mentioned splines, or from the axle nut not being secure) and the overall condition of the teeth on your sprockets. Make sure you have the correct tension on the chain in the first place too. If your chain is slipping though, you're in for some possibly bad damage, so take care of it now. Quote
Malott 1 Posted January 9, 2007 Report Posted January 9, 2007 This style chain tensioner works really good up front. You should run the regular slide on the back also. If that is a new aftermarket swingarm be sure and check the alignment. It's not uncommon to have one a little out of alignment. Quote
Animalman294 Posted January 9, 2007 Report Posted January 9, 2007 The amount of tension should be the same as it was for the stock chain. The only thing you did was change the length of the swinger, but if you put more slack in it when you get on it, the chain will slip............ Quote
jbooker82 Posted January 9, 2007 Report Posted January 9, 2007 This style chain tensioner works really good up front. You should run the regular slide on the back also. If that is a new aftermarket swingarm be sure and check the alignment. It's not uncommon to have one a little out of alignment. Where do you get this chain tensioner? Quote
KEVSWS6 Posted January 9, 2007 Report Posted January 9, 2007 Where do you get this chain tensioner? Jeff at FAST may have them. I got mine from Sandtoyz Unlimited. 818-500-7263 Quote
highroller355 Posted January 9, 2007 Author Report Posted January 9, 2007 guys thanks alot put the guider on and tightened the chain seems pretty good chain might be a little to tight but just set it fast to check it no jumping i will readjust it tomorrow who mmakes that chain tensioner i am def ordering one Quote
CadillacBanshee Posted January 9, 2007 Report Posted January 9, 2007 Check the teeth on your front sprocket. My bike did the same thing when i extended it and it was just the front sprocket was worn out. And yes you should have the rear guide on. Quote
