highroller355 Posted December 6, 2006 Report Posted December 6, 2006 (edited) i have an 87 but my rims fit on my friends 2006 limited addition black rimmed shee looking to buy a set of rims with some type of tires for the snow but dont want to buy the wrong ones heard there were 2 types Edited December 6, 2006 by highroller355 Quote
Bansh-eman Posted December 6, 2006 Report Posted December 6, 2006 (edited) theres 2 differant lug types... the 4lug 115 that the bashee and most yamahas use... and then the 4lug 110 i think is the other its the one that the blaster uses... when you get your wheels they should ask you what year it is for... edit:or make rather Edited December 6, 2006 by Bansh-eman Quote
bansheefreak Posted December 7, 2006 Report Posted December 7, 2006 just tell the guy you need rims to fit an 06 if the your wheels fit an 06..you must have newer hubs.. if you say 87 they won't fit cus there bigger.. a blaster hub is diff then both but you can put banshee hubs on a blaster axle cus splines are the same.. i know this cus i have blaster for my son and swapped hubs to run my banshee wheels ..plus my bro used to have an 89 and his hubs were diff so we got 04 450 hubs put on his so now we all run same wheels 91 or newer banshee hubs (bolt pattern)basically Quote
