cuddie 1 Posted November 19, 2006 Report Posted November 19, 2006 Hey I have a 87 Banshee it has T-5's K&N filters in the stock air box with no lid, twist throttle, key switch removed other than that its stock. When I am ridding or just running it in the garage it will start to die out and at wide open throttle it just bairley stays running and will not rpm up at all if you shake the bike a couple of times it will stop and run great. I have a clear fuel filter on it and when it does it the filter is always full. The bike has never even fouled a plug??? Help! Quote
NEVER SATISFIED Posted November 20, 2006 Report Posted November 20, 2006 have you taken the carbs bowls apart? Quote
Satsol67 Posted November 20, 2006 Report Posted November 20, 2006 Try taking the filter off and see what happens. I have heard people having problems with inline filters. I personaly dont use one the tank has a filter in the petcock. Or whatever its called. Quote
Animalman294 Posted November 20, 2006 Report Posted November 20, 2006 I've heard a people using the wafer filter's and not having any problems. take it out and if it solves the problem get rid of it. If it doesn't then put it back on and look elsewhere............ :beer: Quote
