after doing some searching i found out how to install the bearing. but i was unable to use a washer on the outside with the locknut because i wouldn't have enough threads on the adjuster. i degreased the threads and put some medium strength locktite and tightened the locknut real tight. so i was wondering if anyone else has intalled the bearing without the washer? do you think that it will come loose?
here's a pic.
here's a pic.
The locktite should be fine. When you look close at your picture, there are 1/1/2 threads showing. Isn't that how thick the lockwasher is?
