nope, your shocks and tire diameter effect lowering/raising..........
there are different a-arms that can have different ground clearence.
+2 is width out from centerline................(wider)
+1 is set forward of hub centerline from stock.............(closer to frontend of frame)
hope that clears it up!!!!!!!!!!!! :beer:
Edited by JET 99
+1 from the centerline of frame balance point to the front hub center line =longer wheel base.... ie 1 inch closer to frontend of frame :blink:
Edited by JET 99
