I recently bent my stock handlebars and I am getting Pro-Taper SE handlebars CR-High bend style. Will my stock clamps work or will I have to go with R.I.S. designs, Cascade, or an Ebay clamp? If I do which is the best clamp to go with? Cascade clamp? I am looking to relocate my key also.
Stock clamps wont work. And that Gibson clamp is for a anti-vibe stem. You'll have to find some 1 1/8" adapters. I'm pretty sure Trail Tech makes them and I've seen a few on ebay. I bought the TAG T2 kit for mine.
instead of doing a hide-a-key... eliminate your key all together... follow your key wires down to the plug... unplug it and the bottom half of the plug should have 2 wires... cut the plug off and splice the two wires together... get some liquid tape at walmart... and use that to seal the wires so no dirt water or anything gets in and it dosent short out on any metal... and your good...
I received my silver Pro-Taper SE handlebars. They fit great, CR-high bend is different but I might grow to like it, haven't drove it enough yet. I am waiting on my Hide-A-Key kit from Modquad.com. I bought a Moose 7/8" bar clamp from www.denniskirk.com.
