I am currently having done a F.A.S.T. dune port 4 mill stroker, with 35pwk, CPI Inframe, noss head custom domes, v Force2, Weisco pistons, K&N cut air box lid, lightened flywheel, timing advance +4, I know all run different just looking for a range.
Basically what are you guys getting with your motors similar to this setup?
And what is stock Max RPM and what will it be about.
Thanks for your serious input.
Edited by 2004LEBanshee
anyone with similar mods experience HP numbers as similar to this?
My mods are very very similiar...(I just have 66 bore)......Before i had CPI's and the lightn'd flywheel........I was running 71 - 72 hp.......(that was with T-5's)
You should have no worries jeff at fast builds a hard running motor. There will be no disapointments, I dont even have one from jeff but I can tell you he is one of the better builders out there :thumbsup: He came to colorado (8500 ft above sea level and snowing and cold) With no jetting and ran hard with all the local people that had run here before. His 4mm with a big guy on it ran real hard you will be happy.
Same motor I had Jeff build me, not real sure about hp numbers but I will tell you this...........Those 4 mill Jeff builds are nasty, you better be prepared to hang on, mine hauls ass and talk about pull....it never stops. It will put a huge smile on your face, that for sure. :biggrin:
