i have shifting problems with a 1995 banshee i just bought. its hard to get into neutral and has alot of play in the shifter.i have problems downshifting because of so much play.i just read about a new product called shift pro shift kit and it sort of said it will correct my problem.it this true?has anyone ever heard of this?is it something that is hard to install?can i do it with a repair manual and do i need special tools? i hope someone can shed some light on this for me.
the shift pro makes the shifting smoother .... it sounds like in your case you need to re-adjust the clutch. open your clutch cover up and the adjuster screw right in the middle of the pressure plate is where your going to make your adjustments.. get your self a clymers and it will tell you step by step how to do it.
