Bansh-eman Posted September 10, 2006 Report Posted September 10, 2006 ok so i need to check my math cause its not coming out right... i did the math off a chart and per the chart for every mm stroke you get about 6.5 cc displacment and for every mm of bore you get 11 cc of displacment.. but the math isnt adding up right becasue a stock bore 4 mm stroker is a 370cc and a 4mm stroker with 68mm bore is a 421cc.. anyone know what the actuall displacment is for mm of both stroke and bore? Quote
Big Blue Posted September 10, 2006 Report Posted September 10, 2006 I came up with 7cc for 1mm of stroke and 12cc for 1mm of displacement. Quote
Bansh-eman Posted September 10, 2006 Author Report Posted September 10, 2006 I came up with 7cc for 1mm of stroke and 12cc for 1mm of displacement. then that pushes it even farther away from the displacment .... how is everyone getting 421 with a 68 bore and 4m stroke? the math isnt adding up right what the hell am i forgetting? stupid multi post is screwing it all up lol Quote
Big Blue Posted September 10, 2006 Report Posted September 10, 2006 (edited) You can delet post, the option is next to quote, reply, and edit. Is stock bore 64mm? if so with a 4mm crank I come up with 373cc, and for stock bore and stroke it is 347cc. Edited September 10, 2006 by Big Blue Quote
Dinner Posted September 11, 2006 Report Posted September 11, 2006 Not sure if this will help at all. But what i do to find out what cc something makes is this: (I'll use stock bore and stroke)...bore X bore X stroke X .0007854 X 2(number of cylinders). So it would be: 64 X 64 X 54 X .0007854 X 2 = 347cc Maybe this will help :shrug: Quote
Bansh-eman Posted September 11, 2006 Author Report Posted September 11, 2006 Not sure if this will help at all. But what i do to find out what cc something makes is this: (I'll use stock bore and stroke)...bore X bore X stroke X .0007854 X 2(number of cylinders). So it would be: 64 X 64 X 54 X .0007854 X 2 = 347cc Maybe this will help :shrug: awsome that works perfect thnx Quote
Polish Posted September 11, 2006 Report Posted September 11, 2006 What if you have a 5mm long rod? :shrug: Quote
bansheeseat$$ Posted September 11, 2006 Report Posted September 11, 2006 What if you have a 5mm long rod? :shrug: Longer rods do not effect your stroke. Quote
Bansh-eman Posted September 11, 2006 Author Report Posted September 11, 2006 Longer rods do not effect your stroke. indeed Quote
