Ok, I can't figure this one out, thought I had my jetting all down, it was runnin' so good, but today I went out to tool around in some trails behind my house, and I noticed 2 things
1: The engine bogs and does if I rev it too quickly in neutral.
2: It idles much better with the choke out.
It runs perfect when in gears, and doesnt bog off the line, so I'm guessing it must be the slides or the fuel/air mixture screw. Can anyone give me some insight? It is the 2002 Banshee with the mods as lsited in my sig. My main is a 260, and my pilot is a 27.5, clip is on the middle needle position. Thanks again for the info!
wow, with all the times I've had to ask for jetting help on here you'd think I'd get the hang of it. :shoothead: , yes, I still have the airbox on, with the lid. I also run at sea level, at around 60-70 degrees. It's running fine now, with a 260 main and a 27.5 pilot, I was able to adjust the air screw to lean out the micture. I was wondering though, how many times can I turn the air screw out before I should change my pilots? And when the air screw comes out far enough should I be going down or up a size on the pilots? Thanks again!
