the left side of my crank case is full of water.. there was a rip in my intake boot, and rain water got in.... a lot of it! what should i do.... do i have to split the cases or can i use a shop vac and suck it out? will there be any damage to any bearings or anything in there? any help would be greatly appreciated
I'd take it apart and clean everything really good. Are u talking about the crankcase itself filled with water or the flywheel cover?
drain the gas and oil. tip the banshee upside down and remove sparkplugs. crank over with kick start (by hand) untill all water is gone. then flip right side up and dump some oil in there. you gotta get that water out quick before youre shit rusts.
