I don't even think you need to get a special one, you can get the stock one form the dealer for under 1.00 and it will fix it. The original one just wears out. I am sure you could use a generic one also.
:beer: You got it man just get a bigger as in thicker o-ring and put it where the old one is. I did this months ago and i have yet to hear it rattle.
also I rotated mine so that it hits the cover(fwd) so it doesn't get loose (rattle) from new & put a piece of hose on the part that would be hitting the case (so it doesnt ware it when returning to up position.)
actualy previous owner did it w/o hose & it scarred (sp) the case but I hosed it & it seems all good now?
might want to do that after you replace gutts?
FIXED!!!!!! replaced the spring, bearing, oring and bolt, and it's good as new now! the spring was so worn out it wasn't putting any pressure on the bearing, so i think that's why it was rattling so bad.
total cost $8..and i still have 4 bearings and 4 bolts left. (minimum purchase 5 each)
--matt
