Big Blue Posted June 24, 2006 Report Posted June 24, 2006 (edited) Parts need to go...................... pics available on request. My stock 04 plastics cut fronts billet flame grill 120 Stock tank with dual feed pigel and billet cap 110 Front hubs 40 Front Calipers 40 Front spindles 50 rear Brake hub and rotor 40 Sprocket hub 35 Stock timing plate 5 +7 degree key 15 brand new 2 stock swingarms 20 each Polished dogbone with linkage 40 20/10/10 8 paddle regular haulers 1 paddle torn 80 2 41 tooth rear sprockets 20 each carb to air box boots 10 front fender brackets 10 stock throttle cover 5 head lights low hours 55 grab bar scrapped up a little 10 exhaust boots 10 200w RS stator and trail techs w/ 50w bulbs 210 stock flywheel 45 35pwks with filters and billet intakes 400 Edited June 24, 2006 by Big Blue Quote
CFM Posted June 24, 2006 Report Posted June 24, 2006 Parts need to go...................... pics available on request. My stock 04 plastics cut fronts billet flame grill 120 Stock tank with dual feed pigel and billet cap 110 Front hubs 40 Front Calipers 40 Front spindles 50 rear Brake hub and rotor 40 Sprocket hub 35 Stock timing plate 5 +7 degree key 15 brand new 2 stock swingarms 20 each Polished dogbone with linkage 40 20/10/10 8 paddle regular haulers 1 paddle torn 80 2 41 tooth rear sprockets 20 each carb to air box boots 10 front fender brackets 10 stock throttle cover 5 head lights low hours 55 grab bar scrapped up a little 10 exhaust boots 10 200w RS stator and trail techs w/ 50w bulbs 210 stock flywheel 45 35pwks with filters and billet intakes 400 I'll probably take the plastics and rear rotor. Pics to [email protected] Thanks Quote
Big Blue Posted June 25, 2006 Author Report Posted June 25, 2006 Plastics are sold pending funds. I still have the rear rotor. Quote
axhole Posted July 2, 2006 Report Posted July 2, 2006 are the stock headlight still available ? i really only need one but i will buy the pair Quote
strokrbanshee1 Posted July 2, 2006 Report Posted July 2, 2006 I sent you a pm about the flywheel........ Quote
Big Blue Posted July 2, 2006 Author Report Posted July 2, 2006 stock headlights are still available, Ill have to look for the flywheel..... Quote
