i was replacing my piston and i forgot to drain the head is this bad??
You def want to get that coolant out of there before you fire it up (compressed air)
Just give it an oil change and you'll be fine.
Yes but make sure you use peanut oil because it has a negative effect on gravity and shoots the water out of the crank casing where a two stroke should have oil!
Just put a rag over the top of the crankcase and use a blow gun to blow down in there. ONce you get most of it out that way, take a rag, and crumple it up, then put it in the case and slowly spin the crank. You can stop when the rag gets to the bottom to let it soak up any excess.
After you do this, apply some oil to the bearings, and spin the crank.
No big deal.
  • 2 weeks later...
