87sheerips Posted June 2, 2006 Report Posted June 2, 2006 Looks like I need to replace my shift rod seal. It drips a little bit, probly a teaspoon a day. WHere can I find just that seal?? Quote
98bonerSTOCKshee Posted June 2, 2006 Report Posted June 2, 2006 Looks like I need to replace my shift rod seal. It drips a little bit, probly a teaspoon a day. WHere can I find just that seal?? I noticed mine is starting to leak also... Yamaha prob. the best bet! Quote
KlotzBanshee Posted June 2, 2006 Report Posted June 2, 2006 I got one for like three bucks maybe? Got it from Wheels USA - Yamaha Dealer, Oxford MI. Quote
jankab Posted June 2, 2006 Report Posted June 2, 2006 I got one for like three bucks maybe? Got it from Wheels USA - Yamaha Dealer, Oxford MI. Here's the part# 93102-12321-00 Quote
87sheerips Posted June 2, 2006 Author Report Posted June 2, 2006 Here's the part# 93102-12321-00 cool, thanks fpr the details! Quote
98bonerSTOCKshee Posted June 2, 2006 Report Posted June 2, 2006 http://www.yamahaoftroy.com/fiche_select.a...=93102-12321-00 yamaha of troy has them I just found it Quote
87sheerips Posted June 2, 2006 Author Report Posted June 2, 2006 http://www.yamahaoftroy.com/fiche_select.a...=93102-12321-00 yamaha of troy has them I just found it Sweet! Thanks a lot for the help Quote
2twin350s Posted June 3, 2006 Report Posted June 3, 2006 Sweet! Thanks a lot for the help if your bushing in the sator cover is worn where the shifter rod passes thru,you will toast that new seal in a month.you need to make sure that bushing in the staor cover is good.it keeps the shifter rod centered so it does not put pressure on the seal. Quote
87sheerips Posted June 3, 2006 Author Report Posted June 3, 2006 if your bushing in the sator cover is worn where the shifter rod passes thru,you will toast that new seal in a month.you need to make sure that bushing in the staor cover is good.it keeps the shifter rod centered so it does not put pressure on the seal. do u know where I can get that bushing??? I might as well replace them both while im in there. Quote
racer Posted June 3, 2006 Report Posted June 3, 2006 do u know where I can get that bushing??? I might as well replace them both while im in there. dealer. a decent dealer should have a fiche and it will have each end every single part numbered, and priced. Quote
87sheerips Posted June 4, 2006 Author Report Posted June 4, 2006 yea, but who wants to waste money at a dealer man??? theres always a cheap route! Quote
2twin350s Posted June 4, 2006 Report Posted June 4, 2006 yea, but who wants to waste money at a dealer man??? theres always a cheap route! i dont think that bushing can be bought seperate. you have to get the whole stator cover. now the older shees ran a brass bushing in the cover.the newer stator covers 04 and up ran a nylon bushing.best bet is to get a nice newer cover from ebay.about 20 bucks.or i have heard of people making a bushing for them.those are your only options Quote
87sheerips Posted June 4, 2006 Author Report Posted June 4, 2006 i dont think that bushing can be bought seperate. you have to get the whole stator cover. now the older shees ran a brass bushing in the cover.the newer stator covers 04 and up ran a nylon bushing.best bet is to get a nice newer cover from ebay.about 20 bucks.or i have heard of people making a bushing for them.those are your only options cool, good ideas. Ill just have to check the play in that, or make a new one. Quote
87sheerips Posted June 4, 2006 Author Report Posted June 4, 2006 http://www.yamahaoftroy.com/fiche_select.a...=93102-12321-00 yamaha of troy has them I just found it i cant find this part on the crankcase diagram. All i could find was a bushing where the shift rod comes out. Any help?? i just want to make sure that im ordering the right seal.. thanks Quote
