MagsDragon Posted May 11, 2006 Report Posted May 11, 2006 (edited) I have just installed a new thumb throttle and, cable in my banshee. Well the thumb thtottle was used the the cable is brand new. I installed everything correctly, and it works it is just abnormally hard to press the thumb throttle, my TORS are removed so i just have a caped aftermarket 34mm (I believe carb). Any requestson what to do or how to fix this? Edited May 11, 2006 by MagsDragon Quote
DIRTMAN350 Posted May 12, 2006 Report Posted May 12, 2006 Make sure your carb slide is ok. Make sure you didn't get a kink in the throttle cable while installing it. Quote
MagsDragon Posted May 13, 2006 Author Report Posted May 13, 2006 Thanks, Ill check that as soon as I get a chance. Quote
