braxton Posted April 26, 2006 Report Posted April 26, 2006 frame on ebay now stock cdi $50 shipeed coil $25 shipped http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMESE%3AIT REAR carb boots $5 shipped stock intake boots $7 shipped sold ported cylinders need 2 hole heli coil dealer says its on a 66 bore $130 sipped stock head $25 shipped vito's 65.00mm piston has 15-20 hour on them comes with rings and clips and all $40 shipped axle $60 and 15 shipped on off switch $25 shipped 5 shipped stem $35 shipped lower arms $35 each 6 still for sale wire harness with no cuts $35 shipped voltage regulator $5 shipped stock rear rims minor scuff around the edges $30 and 25 shipped upper left arm $30 shipped kn filter and pro flo ALUMINUM adaptor $65 shipped gas tank $35 shipped rear brake system $60 and 15 shipped brake pedal $11 shipPed shifter pending :SOLD 6-pack rack $65 swinger bolt $10 shipped 1 LEFTT swingarem $60 SHIPPED cairrier CARRIER SOLD motor controlor $5 shipped stock carbs with tors and cable $50 shipped stock front bumper $5p/s has small dent in front an no end caps also have an 88 frame $270 shipped 02 tranny SOLD stock skid 5 p/s tumb throttle $20 shipped sold renthal handle bars on ebay rear sprocket hub and sproket $25 shipped rear break hub and rotor $25 shipped STOCK AXLE LOCK NUTS $5 shipped chain adjusters 5 shipped per set 6 set clutch cable and leaver $25 shipped keep in mind that you will pay the pay pal fees Quote
zirish69 Posted April 26, 2006 Report Posted April 26, 2006 Dude,,i want the swingarm bolt and chain adjusters!!can i send you a money order? 98 frame great shape.vins are on it. i have no title $370 shipped in us. stock cdi $50 shipeed coil $25 shipped axle $60 and 15 shipped on off switch $25 shipped 5 shipped stem $35 shipped lower arms $35 each wire harness with no cuts $35 shipped voltage regulator $5 shipped stock rear rims minor scuff around the edges $30 and 25 shipped upper left arm $30 shipped kn filter and pro flo adaptor $65 shipped gas tank $35 shipped rear brake system $60 and 15 shipped shifter and brake pedal $25 shiped 6-pack rack $65 swinger bolt $10 shipped swingarem $85 shipped with carrier motor controlor $5 shipped stock carbs with tors and cable $50 and 10 shipped stock front bumper $5p/s has small dent in front an no end caps also have an 88 frame $270 shipped 02 tranny with no shift drum or forks $90 shipped. stock skid 5 p/s tumb throttle $20 shipped axle nuts $5 shipped chain adjusters 5 shipped clutch cable and leaver $25 shipped keep in mind that you will pay the pay pal fees 508311[/snapback] Quote
flea49 Posted April 29, 2006 Report Posted April 29, 2006 I will take the trainy if you still got it??? Quote
Shee-Male Posted May 2, 2006 Report Posted May 2, 2006 need a rear chain slider, $? and also lookin for another stock grab bar. Quote
