Hi i get my new 06 banshee this weekend. :dance:
I think this is a great site and loads of info to hand. :headbang:
the mods up to now are ...
alien pipes
carbs re jetted for the above
do i need to put some miles on it/run it in before i do any more mods?
i have some v-force 3 reeds coming
a ricky stator with adjustable timing plate and flywheel
and a procom cdi box
Can you advise me about setting the timing up?
should i set the plate to 4+ like every one says in my search results?
If i do can i then fit the new cdi box?
or am i doing the wrong thing fitting both the timing plate and the cdi box?
i also know now from my search's that i should check the plugs to see if im running rich/lean with the new reeds in.
You need to see if the CDI advances the timing, too...
I'd hate to see you advance the plate 4 degrees...and have the CDI do the same thing...you could be headed for trouble.
Also...if you didn't already order the Ricky Stator Flywheel, it's probably cheaper to get yours lightened...Boonman will lighten yours for 65 bucks, and he eats return shipping for HQ members.
504562[/snapback]
Thanks i will check the cdi unit first.
i got my flywheel and stator today. im in the uk so would have been a pain to send my flywheel.
Yep...understood.
Lightened flywheel and the timing advance are two great, cheap mods for response and power...I loved mine!!
:cheers:
504586[/snapback]
dajogejr do you know,is the ricky flywhell lightened or does it just have the stronger magnets in it?
i just found in a search that the ricky flywheel is not lightened,
Im going to do a dc conversion with the ricky stator so is it a waist of time fitting a ricky flywheel?
should i just use my stock flywheel?
Very good question....not sure.
I've read up a bit on high output stators...but not a DC conversion.
I'm not up for riding at night, anyways...shit comes up real, real fast with no light...
:o
I'd get a straight answer from RS himself...they're good people to deal with!
:o
504607[/snapback]
there is a lot of night riding in the uk. most of it is on the roads tho so the street/road lights help.
check Duncan Racing for flywheel mods..........great place and people here in San Diego, I heard Ricky Stator was backordered, But ALBA has a lot of there parts on Hand :)
