00tbanshee Posted April 13, 2006 Report Posted April 13, 2006 i was wondering if i have the right jets in cause this might sound weird but when it is cold or cool my shee runs real strong through all the gears but now that it is getting warmer out it seems not to run as strong i was wondering if it might be alittle rich and maybe i should drop down too 320 jets i have 340 in now another thing is there is a little fuel and oil coming out around my pipe where it hooks to the cylinder so that made me think it might be rich too. should there be a rubber o ring there i am running t5 pipes i know stock they do but was no sure about the t5's. one more thing is my needles r stock but the clip is moved down 1 from the middle so the needle sets higher not sure much about the needles so any help would be great Quote
banshdog Posted April 13, 2006 Report Posted April 13, 2006 Colder weather requires larger jets. Those same jets in warm weather will cause you to be on the rich side..... go to 330's or 320's and see how she runs. Quote
dajogejr Posted April 13, 2006 Report Posted April 13, 2006 Other than T5's...what type of air filtration are you running, stock air box, snorkle, clampn filters, removed lid? What's your elevation, too? Banshdog is right....Colder weather requires on average 1 to 3 main sizes bigger, and of course you have to lean back out for warm weather. Your needles in the middle clip should be fine unless you have aftermarket reed cages... Quote
00tbanshee Posted April 13, 2006 Author Report Posted April 13, 2006 Other than T5's...what type of air filtration are you running, stock air box, snorkle, clampn filters, removed lid? What's your elevation, too? Banshdog is right....Colder weather requires on average 1 to 3 main sizes bigger, and of course you have to lean back out for warm weather. Your needles in the middle clip should be fine unless you have aftermarket reed cages... 501469[/snapback] i am running rad valve reeds and cages the cages are ported my needle is one down from the middle does that sound ok. i changed too 320 mains and it now feels alot better Quote
Wicked98Shee Posted April 14, 2006 Report Posted April 14, 2006 in order to find out where you need to be on the needle. 1st you must get the main dead on .. then run a half throttle plug chop ... adjust your needles accordingly Quote
00tbanshee Posted April 14, 2006 Author Report Posted April 14, 2006 in order to find out where you need to be on the needle. 1st you must get the main dead on .. then run a half throttle plug chop ... adjust your needles accordingly 501755[/snapback] u mean run it at half throttle then shut off n pull plugs Quote
