hotrodbanshee Posted April 12, 2006 Report Posted April 12, 2006 Are there premix oils out there that run cleaner than others? I get a lot of carbon buildup on my exhaust pipes. Also my plugs get pretty black. i am running castor 927. I know my jetting is not rich. I have one bottle left and was thinking about switching to something else. Are there any other oils that will burn cleaner? Quote
gregbowler Posted April 13, 2006 Report Posted April 13, 2006 I use Motul 800 @ 40:1 seems to work good Quote
knight_ripper Posted April 13, 2006 Report Posted April 13, 2006 I use Bel-Ray everything. Have for 10 years without fail. Good stuff. pre-mix tranny oil brake fluid Quote
Wicked98Shee Posted April 13, 2006 Report Posted April 13, 2006 the cleanest motor ive ever took apart ran honda hp2 @ 40:1 ... i run klotz in my shee's but, castor927, golden spectro, belray,amsoil,klotz,hp2 are all exellent premix. change ur plugs and go chop it... see where ur at cause if theyre burnin' black chance's are ur fat. i've jetted a bunch of bikes runnin 927 and they burn fine, a nice perdy tan color. Quote
cdwood37 Posted April 16, 2006 Report Posted April 16, 2006 The thing with castor oil is that it is made from the castor bean and is not petroleum based, it will lube a motor better but it will also gum them up much faster. Castor oils are used primarily on motors that are torn down every 40 or so hours, or race engines. just my two cents i ran motul 800 for three years and now run bel-ray. Quote
fastbanshee8 Posted April 16, 2006 Report Posted April 16, 2006 You will get more carbon build up, from castor based oils. It's just the nature of the beast. Quote
hotrodbanshee Posted April 17, 2006 Author Report Posted April 17, 2006 I think I might switch to petro based oil. Quote
DIRTMAN350 Posted April 17, 2006 Report Posted April 17, 2006 KLOTZ SuperTechniplate 503552[/snapback] That's exactly what i use. Hve had good luck. Once you switch i would stick with it. Just my $.02. Quote
hotrodbanshee Posted April 18, 2006 Author Report Posted April 18, 2006 Is'nt that castor based oil. Quote
Slayer1018 Posted April 18, 2006 Report Posted April 18, 2006 I also just bought some of this stuff but havn't tried it yet... Is it safe to use w/ KLOTZ? Quote
sp1tekiller Posted April 20, 2006 Report Posted April 20, 2006 I'm running Klotz R-50. Works real nice! Quote
hotrodbanshee Posted April 20, 2006 Author Report Posted April 20, 2006 Thinking I am going to try Bel-Ray H1R. Quote
Banshee~ Posted April 21, 2006 Report Posted April 21, 2006 (edited) Thinking I am going to try Bel-Ray H1R. 505290[/snapback] Ive had good luck with that oil. I want to try ben oil because it smells real good, but on the back of the bottle it says you cant run the oil under 35F. Edited April 21, 2006 by Banshee~ Quote
Malott 1 Posted April 21, 2006 Report Posted April 21, 2006 Thinking I am going to try Bel-Ray H1R. 505290[/snapback] That is a very good oil. Quote
